Changing Head light bulbs
Is there an easy eay to change the headlight bulbs? I finaly got hold of the 9007's in the UK, in the maual it says pull up the 2 tabs slight out the assembly, no probs! but getting it back in so it goes onto the sliders Impossible without removing the grill, the inside side of the light will not slide on as it is at an angle? and pointers? Thanx Mike
Yeah you are right! I have had to take off one of the guides on the headlight so i could get it back on the truck scratched up the paintwork a little around the housing to im not happy, wen i have more time I will take the grilloff and put them in properly again. Do you know if you have to take the headlight out? is there not away to do it leaving it in? the otherside seems even worse and the water bottle is in the way o cant even put your hand in there! what a nightmare! lol#
Mike
cecil.house@btinternet.com
Mike
I think that you are trying to hard. I've done it several times and it goes much easier when you have a extra set of hands holding up those goofy tabs. The lights as you know don't go in straight, so moving or angling the guide tabs is essential.
Just slow down and get a little help. It will work. Good luck.
Thanx for all your help with this!
I am going to attent to change the bulb on the drivers side so i have a matching set of bulbs, I hope it will go easyer!
PS are the HID's easy to fit and get hold of? I saw a set of headlight somewhere on the net with LED and Xenon in them not sure if they worth changing? they would look good tho! Thanx Mike
