The clunk washers
The cluck washers
Okay, I just installed the clunk washers from David Lynn. I have a question for you folks. Do you leave one of the factory washers off?? (the one closest to the shock) I know on the bolt side, that washer is fixed to the bolt and won't come off, it looks like if you left the other washer on the bolt it would not have enough threads to tighten up good enough, so I left that washer off. Will I have any problems in doing that?? Every thing torqued down okay, I was just wondering if that would cause problems down the road.
Harold AKA MM
Harold AKA MM
Most of the "clunking" comes from the steering stops. If you apply a bead of never-seize to the stops, you'll find that will take care of the problem. Its those 295 tires up front that cause the binding up.
If you do a search for steering stops, you'll probably find more info than you want to read
Originally posted by hyvltge
Does anyone have install instructions by chance??
https://www.f150online.com/forums/sh...threadid=74800
I wonder if this "clunk" you guys are addressing is the same noise that I hear when I am backing up and turn the steering wheel all the way clockwise on my 04L! Sounds liking a "popping" noise in the front end! I noticed it the first week I had the truck, thought it was those big a-- tires hitting something. Took it to the dealer and they said they just lubicated some steering joints that were dry and it stopped the noise.
I just turned 7K miles and now I am hearing it again! I also now notice it going forward slowly and seems like when I am turning hard to the right!
Is this the "clunk"?
Originally posted by MotorcycleMan
Fast Gator is right on the money there. My 03 hardly ever clucked, but I want ahead and installed the cluck washers any way. Heck for 25 + shipping you can't go wrong in my book.
So did anyone else leave one washer off, and if so does it cause any problems???
Thanks again!!
Thanks again!!
