58k intercooler cleaning
My first ic cleaning at 58k with no mods,
Looks like a bit of teflon gone and quite a bit of oil in the valley.
The cleaning is not going so well after many cans of carb cleaner and a few brake and electric cleaner the ic stilll looks the same.
Any suggestions before i give up and put back together?
Got it soaking in a degreaser now will try again in awhile.
Thanks for any help.
Looked like mine after 20k w/o the PCV setup w/ breather...
You sure that when you're hitting it with the carb cleaner you're not seeing any dirty liquid coming out through it? It's been on there for 58k miles, so that oil is BAKED on... gonna take some work.
Good luck, and a worthwhile investment in time
Try acetone.
LMR2 (John) suggested it when I did mine and it made the crap just flow right off. Mine was about 3 times that dirty with about 36K on the ticker (open element filter, chip & 5# lower) and the acetone cut right through it. Mine to 12 to the chest (12 cans of brake cleaner) and was laughing at me. I then hit it with the acetone and - GAME OVER GRIME!
I kept the IC attached to the midplate and proped the assembly over an open tupperware storage container. I poured the acetone from a small cup (not styrofoam) through the IC fins one section at a time. I kept repeating until the acetone ran clear out the bottom.
Herb
Herb
http://formula88.com/ after 1 pass thru with this stuff i look like this now!
if you are going to clean the ic i would say forget about the carb cleaner this stuff is excellent.
now should i use it on this?
WOW - where do you get that stuff?
Check the label carefully - I use Superclear on everything, but the label say not to use on aluminum. I ignored it and cleaned some carb parts on my Jeep - not good. The casted effervesed like crazy and the passage clogged with white scaley crap - new carb fixed it though
BTW this was mine before cleaning...
Herb
Herb
Home Depot,
Pep Boys, Advanced Auto Parts,
Winn Dixie, Navarro,
Sedano's
and many other retail outlets just ask.
https://www.f150online.com/forums/li...formula88.com/
Herb, seems like its okay as long as ya rinse it real good or so it says.
i like the idea of a basket and just pouring it thru till clean, i willl try it next time.
hopefully with a seperator or two i wont need to do it again.
so no quick easy clean up tips for the throttle body?
Sedano's
