Rearend alignment?
Rearend alignment?
Has anyone noticed their rear not centered in there L? My rearend sits to the right about 1in. off. Other than the look of this , it has not affected driving, tire wear, or launching at the strip. My L has been getting mid 1.5 60 ft. times. It has been to an alignment shop and all was ok, no frame damage could be found. I thought it could be because of the bed being misaligned, but it is strait. Any thoughts?
Josh
Josh
When I lowered my 01 with A arms, front spring hangers, and shackels before I went to the alignment shop I measured up everything. By my measurements the rear axle was out more than a 1/2 inch (not square with the front wheels). So when I had the alignment checked they confirmed my measurements. I took out one of the rear front spring hanger brkts, welded up the spring mounting hole and redrilled it. I am not sure it makes any difference, rear tire wear will not be an indicator.
