just brain storming here..need some suggestions
ok first off i wana say im 95% sure i will never take the lightning to the track..this will be a everyday daily driver if not at least 3-4 days of the week..i went to a few websites and im no genius at this stuff..so if any of you bros can make any suggestions of the stuff im interested in please throw in some words thanx
lightning traction bars
lightning predator
lightning diablo sport module
lighting super cooler
cobra r high flow water pump
2-zex wet lighting nitrous kits
zex purge kit
60lb high impedence fuel injectors
set of 8 denso iridum spark plugs
kennel bell boost a spark
+10 lighting crank pulley
air indeuction kit
power flow plenum
lightning long tube headers
lighting h beam rod set
lighting arp head stud kit
if im missing something let me know..thanx
lightning predator
zex purge kit
air indeuction kit
power flow plenum
lightning traction bars.........only needed for the track
lightning predator.....Go with SCT
lightning diablo sport module.........Go with SCT
lighting super cooler..........not needed for a daily driver
cobra r high flow water pump..... Good
2-zex wet lighting nitrous kits....... Good
zex purge kit.......Good
60lb high impedence fuel injectors...waste of money at the power level you will be at
set of 8 denso iridum spark plugs.....Good....NGK works just as good and cheaper
kennel bell boost a spark......Joke Mod
+10 lighting crank pulley.........so you want a built motor??? Go six
air indeuction kit........Good
power flow plenum....good
lightning long tube headers........good
lighting h beam rod set.........Oh..now I get what the 10lb lower is about
lighting arp head stud kit.....If your pulling the heads for these, might as well get them ported
Good luck with it all...
It doesn't look like you have a Lightning now, am I right??
If you don't have one yet here is what I would do.
Find a used lightning with a ton of miles or one with a blown motor.
With the money you save over a low millage Lightning, send it to JDM or whomever you choose, and have them put a built motor and trans in it.
