I cant find the 14mm hex head socket for the crank pulley anywhere do any of you know where i can get one ive called sears and most of the parts stores no one has it
I got mine from an online delaer specializing in Mercedes and BMW tools. The oil drain plug on the old SL380 is a 14mm allen. The only problem is that it's too short for the other 14mm allen on the truck - the oil cooler adapter fitting.
i have one you can borrow if you are in houston. otheriwse maybe someone can loan you one, or worst case, buy some more tools, that is not always a bad solution. you can never have too many.
