4 lb pulley
4 lb pulley
how much of a hp gain would you get out of a 4lb pulley with a predator tune? and what kind of a time increase in the 1/4 would you get if you were on drag radials with the pulley? im talking about with a stock truck and what would you guys say a stock truck with a 4lb pulley drag radials and a 75 shot would run?
gains
hp gains are all different. Depends completely on the tune.
On MOST lightnings, a 4lb pulley with a tune should put you in the 12.8 range.
On Drag radials, you could squeeze some 12.5-12.7's.
Add a 75 shot and your will be approx in the 12.1-12.3 range.
All depends on weather, track prep, altitude.
Good luck.
Good luck.
