Was bored ..So..
Was bored ..So..
I figured I'd solve my spinning tire on the wheel (7 inches so far) problem. Usually after a couple passes the tire would set . But I guess at this power level set screws were inevitable
Start w/ demounted Wheel
Make template (4 sides, It saved a ton of time)
1/4 inch punch
1/4 inch punch
I have seen the srew's many times but always had a hard time wondering why they didn't leak?
Thanks Vin,
Hey my engine is due back any day. The finished day was supposed to be this last Friday. I'm not rushing it I just want it to stay together and get out and do some racing!
Peace,
Suavy
Thanks Vin,
Peace,
Suavy
You might want to use what is called TEK Screws. They have a small drill bit tip on them. So if you pre/drill the rim first with a bit the same size as the tip, than the screw will cut a thread in the rim and the point will hold the bead in place the plus is they also have a flang edge that acts like a lock washer. Been using them for a long time and they work very well. Hope this might be of some help. Artie
