I installed a Ported Eaton (Wasp Generation 2)
#32
Very interesting, indeed. Right now I have a MP with a 6# lower and I'm only making 398/477, and I have a JL intake, SCT MAF with a C/L plenum and a SBTB, with a Bassani catback on the other end. I am very dissatisfied with the output right now and I'm looking for reasons beyond a bad tune.
#33
Originally Posted by Rob_02Lightning
Great feedback and info all ,
AND THANKS FOR KEEPING THIS CIVIL EVERYONE
Like I said, I am not saying this is the end of the Mag,
but I am out of options right now. I've asked Sal many many times
if he would install cams and or springs, and he has told me each and
every time it's a real pita job and he really doesn't want to do it.
(I can understand and respect that)
So I'm kind of out of options and need to do SOMETHING ?
YES I SCREWED UP by NOT doing the heads and cams @$@&($%@$
I know I dont have any magical Mods that should bring me crazy HP,
but since I had @425 HP to start with, when we build the bottom end
all I wanted was an additional 50 HP or so (off n20) so we really didn't
think the Heads and cams were needed.
I DID BELIEVE going from a 4lb lower to a 8, adding a CL Upper, The Mag S/C,
Mag Idler Bracket, Long Tube Headers, Hi Flo Cats, Cat Back, Injectors
(50 lbr's) the 255 Pumps, Maf Extender, new CIA System, and SCT tuning
would give me that.
It's very hard to swallow that all that only gave me 15-20 HP :o
Just freshening up the motor, cleaning up the heads, milling and boring, Having Sal Dyno Tune using SCT should have done that ALONE
26 Dyno's is waaaaaaaaaaaay more than I EVERY wanted my truck to make,
and believe me I HAVE ALL THAT BOOST. It goes to 18 IMMEDIATELY apon stapping the pedal, and then quickly climbs to 22. Sal has had me sit in the truck on many a Dyno pass and watch the guage, and I see it all day on the street. Thats what makes this so hard to understand, I truly have massive low end TQ and Tire Ripping Power, all that Boost, and yet crappy HP : o (
And when I tried going from a 2.7 upper to the 3.0 Mag Upper, I lost A TON of power and immediately went back to the 2.7.
But my other issue is all that boost comes with a price
Even with a very safe AF I have already hurt spark plugs, and even melted the pins out of two inserts and had then unscrew with the spark plugs during a routine plug change &@$^%@*&$%@*$%@$
My Air Temps may be great (and they are) but there is obviously massive Cylinder Pressure and or Cylinder Temp's going on as a result of all that boost.
I'm going to toast a frigging new motor here trying to squeeze a measly 450 HP out of it.....
Mike's #'s are amazing (I would love to have them), and he's using stock heads. I truly believe the Cams and Springs made the diff, and as Charles has proved, I even believe the springs alone would make quite a diff.
But thats over my head to do alone, and Sal doesn't really want to, and if you go that far, why not spend a few more hours and do the Cams,
(prob a good 3K job and right now I just cant)
Of course for the same 3K you could also throw a KB on it, and DEF hit 480-500 HP on stock heads and cams, but I have seen so many give trouble than I dont know if I'd consider that. (I know it's King of the S/C, but there are a lot of failures, NO ONE can deny that)
But mike also has something I WANT, A reg Tune, and A Race Tune,
WE CAN NOT BUILD US A RACE TUNE ???
Basically we have NO TUNING CAPABILITY AT ALL
It puts down the same #'s from 14-16 degrees, and consistantly loses
HP every degree of timing you add over that, WTF RIGHT ???
(and if you go below 14 you lose also)
A/F will of course change the power, but how much over 12 does anyone really want to go ??? Mike I'd love to see the A/F on those Dyno's, Do you know what your timing and A/F was ?
THIS TEST is a must FOR ME, I have got to know if less Boost, and maybe more timing cant give me the same or simular results at a much safer Cylinder Pressure and or Temp.
Charles your a great guy, a good friend, and the Mag has a def place in the L world, I am not giving up on it, and people like Gator having 580 all motor prove the SC can kick *** with the right Mods.
When I talk to Sal this week, I'll get a price on Cams and Springs, beg him some more, and consider going further into CC hell if I am grrnty'd more power with that.......
In the mean time the truck is running amazing, I was out with it all weekend,
although I have a lot less boost, 17 is plenty, and it feels REAL GOOD.
Lets see what HP it's capable of ???
would give me that.
With these new valve spring tools I think changing the valve springs will only be about a 3 hour job plus $100 for 8 aftermarket springs, thats about a 1/10 the cost of doing the cams. I think this is in line with your original goal of the "Budget Beast". I'll get the tools out to Sal as soon as possible so he can see how they work, perhaps he will change his mind.
Charles
#35
Rob, you really need to try the springs. It's cheap enough, and perhaps your original springs are a little more fatigued than some others with same parts running more HP. It has to be something mechanical and solveable. If it is the springs (bad), they will just simply leak your HP right out your exhaust. If I were in your situation, at this point I would try them. Plus, if/when you go with cams and you will have springs out of the way.
#36
Remember - a broken spring WILL = head, and piston damage plus the posability of block damage as well. Don't gamble on it - find a way to do the springs at least.
Get the spring tools from Sal (by way of Charles), buy some beer and BBQ and have some kind of LOONY Bastards BBQ and spring swap weekend event over the 4th of July weekend. You certainly have friends that will help (I'm a bit too far, but I would if I wasn't 1/2 a country away).
Herb
#37
Originally Posted by St Louis Lightning
There is one tuner out there that always gets the best results. No matter the setup, the numbers are always higher than everyone elses. They can take a part like a phenolic spacer and show 10+ hp gains. Now some would say that they have a special gift for tuning our vehicles that no one else can duplicate. And some would say that they put other bolt-ons on the vehicles to exagerate the gains. Others would suggest their dyno just plain reads high.
Bottom line is what has always been true is still true - the real test is at the track where everyone is on the same playing field.
-Mark
-Mark
#38
Has anyone stopped to think that Vinnie paid off Sal to keep Rob's HP down?
Sorry to many pages with no wise azz comments!!!
Rob u will figure it out. Why don't u just pull the motor so u can hand the heads to Sal to do the springs. All u have to do is call up myself and Josh and you will have an entire pit crew at your house to help out.
#39
#40
#42
Hey Rob,sorry to hear about your troubles, keep your head up . If u need a hand im right around the corner. I usually have free time on sundays. Get those spings in and the mag back on. It makes sense what Charles is saying plus maybe your springs are a little weaker than normal ( god only knows how much you sprayed the ***** out of it ). I would have to think they would lose some strength after a while. Add exteme boost and well u see. I have basically the same mods u have but i got worked heads and cams. Im seeing 541 H.P. with my Magnum (and we still have to setup a race tune) And i think im lossing big power still cause i dont have the right tensioner setup yet on. My Magnum is covered in rubber. When it was on the dyno i think we only saw 19 lbs of boost. On the street there was times i saw 21.5.,so i know im losing power. I dont think youll be happy with the ported eaton only cause youll never see the boost like u did with the Mag. My ported eaton would only see 17lbs of boost and dropped off hard at the end to like 12. With the right setup theres no comparison . The Magnum pulls hard and just keeps pullin ! Right now i have a head gasket issue which will be done shortly. After that its back to Sals for a Race tune. Sals done a great job tuning my truck so far. I have all the faith in him. It will all work out for ya. I love my Magnum .its a great product and Charles is a great guy to stand behind it. What more could u ask for.
#43
#44
I just got the spring compressor tool quotes back and placed an order for 6 production spring compressors. I should hear back by the end of the day when I can expect to receive them, hopefully not long. It looks like it will not cost much to have these compressors made so we can have one, even Robo.
Charles
Charles
#45
Originally Posted by 8UR LS1
I made 463/530 on the MP/JDM street tune with stock block and heads w/ 4# lower and 17-18#'s boost
Hmmm, sounds familiar! I witnessed his run. see my sig for #'s. stock block/heads. 4lb/2.73, used 50lb injectors, used 92mm MAF, SCT tuning by JDM. This was a VERY SOFT street program, w/12 degrees timing, and 12.0 A/F. I ran out of fuel pump. (To be honest, I think it was more due to the fact that my lazy azz hadn't changed the fuel filter in a while.) Obviosly something going on, like valves besides the MP.
Good Luck Ronbo!
