New plugs, spray... and now problems?
I'm not really sure what the problem is but last night I put in NgK Tr6 iridium plugs gapped at 40, 50 shot of nitrous, and now it sounds like my truck is missing according to one of my friends. I've heard the noise before though, before any of this was done. It sounds like something is choking, like not getting enough air. Could a lose belt on my supercharger not give it enough air thus causing it to make a choking sound or what could the problem be?
At WOT it's almost like a sputter... That's the best I can describe I suppose. If there is other questions on the problem let me know, as your advice would be greatly appreciated.
40 is a HUGE gap for a N20 L
6's are too hot
Spuddering is ALWAYS a tell tale sign of a bad plug
50 HP of n20 is nothing and should not have hurt anything
If it's not a plug
My guess would be "Spark Blow Out" especially at WOT due to the large Gap.
How does it run at low RPM and Throttle ???
6's are too hot
If it's not a plug
Yep they always do with a burnt plug
You need either BR7's
or
Denso IT -22's
Gap can vary, dont know your other Mods ???
But for n20 some will go as small as .028 -.032
I go larger, Sal gapped my last set so I'm not positive what he used,
however my guess is .034 - 036, thats what I've been using lately.
or
Denso IT -22's
Originally Posted by BLOOWN
Alright, I'll look into new plugs. Thanks guys. Kinda sucks, I think I read a post by rob where he said he was running the tr6's gapped at .40 while spraying that's why I choose that. Next time I"ll research a little better. At least **** isn't broke.
https://www.f150online.com/forums/sh...plasma+booster
Rocks
Love you too Rocks
BTW
I DID gap them at .038 - .040 and they worked awesome
BUT
The Multi Spark helped that work perfect
And BTW I NEVER said I gapped them at .100
I said the Plasma Booster allows you to run up to .100.
OK SO I MESSED UP THE DEC AND WROTE 1.00, kill me why dont you
BTW
BUT
Originally Posted by Rob_02Lightning
I can tell you my set up (Ignition Solution) you can run up to 1.00 Gap "trouble free"
