Boost help..please
Boost help..please
Every time I get up to 5 pounds of boost it stalls.... I have no light on. It is all stock. I changed the feul filter and it still does it. Does anyone have a idea? It runs good till I get into it. and I don't do it except to get on the highway... and it is sad... and scary when it shuts off.
Thats a new one to me ???
Many have that problem once chipped, but you did say stock RIGHT ?
No Chip ?
The only other time I have heard of it not being Chip OR COMPUTER related,
is with Chris's Lightning. The poor guy went nuts, changed EVERYTHING,
to FINALLY find out it was the Alt and Battery.
I assume you have checked all lines, hoses, plug connections under the hood, etc.
What if you go fast and DONT get into boost ?
What if you get into boost hard and then back off ?
Hope someone can add some input, keep us informed and good luck Bro....
No Chip ?
I assume you have checked all lines, hoses, plug connections under the hood, etc.----YES _CHECKED ALL
What if you go fast and DONT get into boost ?No problem ----just when I hit 3/4 boost it stutters and if I am luckyit won't stall out on me!
What if you get into boost hard and then back off ?It will buck like a mule then shut off before I let off
I would guess it has bad plugs or they are gapped wrong too tight or a bad coil pack(s) and when you get into it it sees the cylinder(s) not fireing and shuts off but I would think it would set a code.
Or depending on the year maybe the infamous fuel pump problem is there but I thought the truck would only idle when that happends.
Let us know what you find also did you try to reset the pcm (disconnect battery for like 5 min)
I would also get the pcm checked for codes it could be setting a soft code wich will not set off a ses light and another one just hit me check all the connections for inlet tube to throttle bady air filter I thought this happend to another truck and they found the inlet tube to throttle body was loose leaking air
good luck
Slick
good luck
Slick
Originally Posted by SLICK0478
...another one just hit me check all the connections for inlet tube to throttle bady air filter I thought this happend to another truck and they found the inlet tube to throttle body was loose leaking air...
Slick
Slick
Let us know...
If you need a little info on plug changing....
http://home.midsouth.rr.com/lightnin...parkplugs.html
