Bassani cat back ?
Bassani cat back ?
Was looking for any feedback on the Bassani cat back system. My main question is for those who have or had this system is what's the drone/ resonation like in the cab at normal highway speeds at low RPM's.
Had a bad experience with Borlas on a corvette, the drone was enough to drive a sain person batty. Did a search, a lot of positives on performance and sound at WOT but wasn't much mentioned about cab resonation at low rpms.
My usual cruising speeds hover around 80 mph, and I dont really notice much of a drone at all - I'm able to hold a normal conversation inside the cab without interference from the catback...I know it's there, but its not that loud at all. Friends that I've passed on the freeway, however, definately know that I was there!
I have just the Bassani cat back, everything else is stock and I have not experienced any drone. Not at highway speeds or cruising. For me it’s a perfect exhaust system. It’s a bit loader then stock at idle, but getting on it just a little to a lot it sounds excellent. Something that should have come on it from the factory…
As far as performance you won’t see any, at least nothing noticeable. My understanding from reading many post and seeing some data floating around is you will see NO gains or losses in hp or torque with a cat back, not until you get up somewhere around 450hp or so.
Do NOT buy it for performance on a stock truck or you will be disappointed. I bought mine for sound and sound alone…
All i have is the S'Steel Bassani cat-back on so far, and at highway speeds you don't know it's hardly there. I actually wish it was a little louder,that's why i'm going to get the Bassani high flow catted mid-pipe. Then add some Kooks long tubes, to get a louder & better sound. But even now with just the cat back on, when you get on it the sound is oh' so good! When your on the highway going 75 or 80, and you let off the gas the rumble of the Bassani is music to the ears!
Bassani
Bassani mentions "quite thunder", do they offer different versions of mufflers on the cat back from quiet to louder?
Appreciate all of your feedback. I'm having JLP repair a head from a blown plug next week. I'm was thinking it was time for a few mods (exhaust-chip-pulley-cold air and tune) If I'm going to blow another plug might as well launch it through the hood.
