Use the 01-04 intakes or the 90mm MAF on an 00'?
Originally Posted by l-menace
You Need to have a tune to run the 90mm MAF!
If not your A/F and fuel tables will be all screwed up and you'll be running VERY lean.
yeah i looked into it i decided to go with the diablosport one. i fell i may regret my choice but i guess well find out after i put my 4# crank pulley in tomorrow
are they programmed to specific dach clusters? To avoid Odometer tampering.
The only issue will be if you still have the 3.55 rear end the odometer will read approx. 8% on the low side. So when it indicates 55 you are really at 60.
I don't think that's a big issue as long as you keep it in mind.
An 01+ computer is also a bit leaner which accounts for most of the 20hp gain in 01.
TB
NB. I did a test on a stock 00 on a dyno 80mm mersus 90mm. The 90 will lean the entire A/F line by 2 full points. The 99 and 00 run very rich, as low as 10 to 10.5 at WOT. The leaning of the A/f will give you 35-40hp gain but I don't like the A/F line. IMO it is just too lean in the 3000 to 4500rpm range.
On the other hand one of my buddies has a 99 with a 90 and filter. He runs it reasonably hard and has towed with it for over 4 years. This and many other observations point that timing blows motors more than a reasonably lean A/F. Having said that, I still think that the best option for someone who does not want a chip is to get an 01+computer which will easily allow you to run up to a 4lb pulley safely.
