what are some good fuel additives and oil treatments?
i have used the STP fuel injector cleaner on most of my vehicles except the lightning. used to use the black one every fuel change, now i just use the red bottle every now and then. some mechanic i trusted told me to use the black bottle every 3,000. it makes sense. i figure as hard as the L gets driven she really doesn't need a cleaning, not with the low mileage mine has anyway.
hmmm
Originally Posted by Norm
Prolong is crap. It is chlorinated and can create hydrochloric acid in your crankcase if you do short trips.
Originally Posted by bwkelley76
and what will hydrochloric acid to to your engine(in small doses I would assume, if at all)? I usually commute, so not really worried about it. And where did you get this information?.. PRO LONG is crap? ..sounds like an opinion. You got facts to back that up? ..not trying to argue, just curious. I've never heard anything bad about it, and this is the first time I've heard anything about hydrochloric acid as a byproduct.
ASTM-D-2783 Standard Method for MEASUREMENT OF EXTREME-PRESSURE PROPERTIES OF LUBRICATING FLUIDS (FOUR-BALL METHOD)
http://www.sfrcorp.com/product_comparison.asp
looks like prolong isnt so bad...
The FTC settled a complaint with Prolong, basically saying they couldn't make any claims that the additive does anything beneficial.
Read the details here
http://neptune.spacebears.com/cars/legal/procomp.html
Explains Prolongs legal battles.
hmmm...
Hydrochloric acid etches surfaces. Bearing surfaces are suppposed to be smooth not eroded by acid.
I took that engine apart with my bare hands and saw with my own eyes that everything looked new after NUMEROUS hours of abuse.
Or were you talking about one of the race engines? In case you missed it, the BS was called on the rod knock motor that ran for 30 mins. with no oil. I'd call BS too! It doesn't matter how many crevices something gets into if the bearings are already pounded and the cushion of oil is removed!
Originally Posted by Rayden's cloud
I was just curious as to what were some good fuel/oil additives to use..
http://www.apdinc.com/GTAfuel.html
I'm thinking of shelling out $20 for a trial.
The legal wording in that document souds more misleading thatn they are accusing Prolong of being... I don't see where it SPELLS OUT that Pro-Long is corrosive or doesn't prolong your engine's life. I dunno, legal battles happen all the time, some moron probably tried to run his engine without oil, CLAIMING he used Pro-Long, or whatever. If you have any info, or you can show me something more explicit depicting that it has corroded bearings, etc, then I'll take your word for it.
Most of the legal battle had to do with the fact that Prolong could not PROVE any of their claims. The engine running without oil thing was shown to be a gimmick on another site. If I can find it I will link it. There was also a site showing the acid damage on several engines. If I can find those I will post them as well. Some of them are probably gone as the lawsuit was years ago.
Originally Posted by ganiman
Everything has its "downsides" even regular engine oil, as well as synthetic oil. Synthetic oil actually "RUNS" from heat, but it has to be VERY EXTREME HEAT, so hot that regular oil would boil. So in essence it is the best until it's breaking point. I'd like to see an actual link or a site that works, that maybe sells me on the idea that Pro-Long corrodes our engines when used correctly. Another thing, If Prolong is used correctly, and you put in the concentrate ONE time, and the BOOSTER every oil change, I wonder if that has an effect on proper usage being a factor? I know for a fact that if you use too much fuel injector cleaner you can actually cause damage to your fuel system and engine's internal parts. When used CORRECTLY, how does Pro-Long hurt your engine and its parts?? I mean if it were meant to be used in excess they would just sell it as an engine oil, and kick everyone's butts. I agree that maybe used in excess it may corrode and/or cause problems, as would any other additive. It's like the stuff that they inject in to the blood stream of a blocked-heart patient, it is beneficial upon proper dosage, but will kill the patient and eat throught their blood vessels if given too high of a dose. So, let's say Prolong is a little corrosive, I'll still use half a bottle for insurance cause I've seen the beneficial-gains of the product.
