installed ported blower, lost boost
just installed ported blower and my boost guage is showing only 10lb of boost and rapidly decreases. my mods are 4lb lower, ftvb, tuned, plugs, cai, exhaust. before installing i was hitting 13lbs on autometer boost guage. the installation was not hard we checked everything twice and still don't know what to do? At 1/2 throttle my guage is hitting 0 and at wot i hit 10lbs then rapidly decreases into vac while at full throttle. can anyone please help?
Here's some info on it from Chucks Site
http://home.midsouth.rr.com/lightningpage/tips.html
Boost Actuator Adjustment
The boost actuator is located on the driver's side of the intake close to the firewall. There are (2) 10mm bolts that hold it in place. One you can see in the pic and the other is on the backside of the actuator closest to the firewall. Pay attention to the slots location in reference to the bolts so you will know where you started. Loosen bolts and raise the actuator up until you see the LEVER raise up off of the STOP. Lower it back down until the LEVER just touches the STOP then tighten bolts. Now, this is the way it was explained to me but I found that set this close the boost gauge would rise to almost "0" while cruising at 80. I went back and readjusted so I could cruise at 80 with no needle movement unless I barely moved the throttle (and I mean barely). This setting was probably halfway between the stock setting and the just touching setting. The first thing I noticed was the needle jumped immediately to 10lbs and climbed from there. Stock it jumped to 9.5lbs and climbed. The total boost also increased by a 1/2lb to 1/4lb more. I also ran a tick quicker with my fastest mph at the track. The temps were warmer and there was less traction (it rained until the track opened). I think this adjustment is worth a small amount of speed. Besides, it's free.
i played the with actualor and i am seeing different levels of boost. i am getting some boost back, it feels faster and sounds louder. i put the lever about half way up at seen 13lbs of boost, put it all the way up and are seeing 11 lbs of boost. where should the lever be at? before i touched it it was just touching or barely touching. can anyone tell me where the stock setting is and should it be all the up or down. thanks
I was told this by Dale
I tried it on mine, AND IT WORKS AWESOME,
Been like that quite some time now, and MAN OH MAN does is run strong, and have a ton of Boost. Any slight touch of the pedal will bring me an INSTANT 10-15 lbs of boost, and I'm seeing 17-19 at WOT in 80+ Temps.
THANKS DALE
THANKS DALE
Originally Posted by Bad as L
Rob
loosen the screws on the boost bypass valve and push down on it as far as it will go and preload the spring to its max....tighten the bolts....test drive....tell me what happens
Dale
Dale
hmmm...
THANKS DALE
THANKS DALE
Originally Posted by bwkelley76
Hey Rob, does this pretty much make the boost bypass inoperative, kindof like the boost-bypass vacuum "T" fitting? Thanks, Brandon.
OH YA
Not sure about exactly how the system works, but I do have a reg JDM Boost By-Pass Kit on it too. After I did this and told Sal, he basically said what your saying, it cant dump Boost now
OH YA
i have my top line of mine and it is loud all the time the looks you get rolling through a parking lot at 5-10mph it sounds like a jet plane idling sorta.
