lightning engine electrical problems 99 "
I have a 99 lightning that has 850 miles and it started with a slight hesatation that developed into a slight miss. On the way to the dealer (about 12 miles) the engine seemed to clean out some,as i pulled into the dealership it started runing on for cylinders.The dealer (tech)said it was the mass air flow sensor.They replaced it and one plug. It still has a high speed miss,as soon as they solve this,ill report.****
RA6870
While I applaud you for doing some research .....
Since the search is down it is pretty tough to get 2+ years back in the threads and NOT know you are that far back......
That thread was one of the first 20 -25 threads in the forum....
I'm not sure how suggesting he add more boost and a 90mm maf will help his high speed miss..... Especially since the 99's came with an 80mm and he would need a chip to manage the new maf.
Doug
Doug
