PSP Nitrous Plate Kit-- Adds HP on it's own
Originally Posted by LightningTuner
oldfrmtruck, if you are having issues with the website, just call and order it. Leave a message and Lisa will call back and take the order.
bad00, I am pretty sure our plate works with the ZEX nozzle. It's 1/8" pipe right?
As for the whistling, that's a new one to me. Are you guys sure you've put the tapered plug in the one of the two holes you DON'T use?
As for distance, our plate is only 1/2" thick. That picture Rob posted was of something else and doesn't look anything like ours.
I took and epoxy'd the hole i didnt use on mine.
Originally Posted by Rob_02Lightning
20
That Paint job is amazing
Although I'm not using the plate anymore (I drilled the nozzle into the upper)
I can tell you I've used both the PSP Plate and the Race Tested Plate
(which as said is the same plate double thick) and in both cases it actually helped, not hurt getting those dam lines in the inlet boot. Right now without any plate on there it a MF to get mine in amof (&@$^(@$@$^@$(
thanks about the paint, the bumper and tonoue cover are getting done this week and will be on by the weekend.
