Upper Pulley or Lower Change on 99 Gen 2 "HELP"
I recently bought another 99 with....get this... 590 "original miles" on it.
Anyway, I had a horrible experience with my 1st 99, when I tried changing the upper pulley. Killed the S/C.
A friend has a pulley puller that he purchased for his 04 Cobra, says it's specfically for the Eatons and it works like a charm.
The 99 is a pressed fit pulley, did they change the design of this with newer years? Should I try this again, or go with a lower?
Thanks.
Mike
Thanks.
Mike
I killed it meaning, after I put the pulley on, the S/C was spitting sparks.
I may have used the wrong puller, as it was flywheel puller, Craftsman.
Anyway, it was a PAIN to get it off and then had issues getting the new pulley on. Had to heat it up.
I guess you can say I was probably one of the first guys on this forum to try it back in 99. It wasn't a good idea.
Originally Posted by netoje
I upgraded to a 2lb(2.7") upper last year and used this pulley puller
and had the old pulley out and new pulley in, in about 30 mins. It was a piece of cake and it was my first time doing it. If its the right puller it should be a breeze.
what kinda ****in puller is that?
if your gunna do an upper get a amazon/ billetflow puller
Lower pully is all I ever plan on messing with, it offers more flexiblity:
common sizes: 2, 4, 6, 8
other sizes that can be found: 3, 5
Plus, (for me) after the first lower pully change, it's easy as he11 now. The first time took me 2+ hours, now I'm down to 30 mins after the truck is lifted on the rack at FT Belvoir.
