New Brake Options????
Does anyone know of any new brake products that have recently been released?
Is the TCE kit still one of the best bang for the buck values?
I know a lot of you guys are using Ruslow's and Rotorpros products. Are there any other compareable products???
I am looking to do a brake upgrade and I am weighing my options. I am either going to go all out with the TCE kit or save some money and stick with just new rotors and pads (rotorpros or Ruslows).
I don't see why you would have to upgrade your braking system? I can almost lock mine up at any given moment, except for the abs! That tell's me there's adequate stopping power.
Probably the only thing I could do is stick a bigger tire on for more stopping power, not too sure how that would work with abs?
Now, if you're road racing and doing alot of braking, brake fade will probably occur. So, you need to get rid of heat and need an upgraded system.
But, on the bling factor, those rotor's will get attention!!!
Bryan
Bryan
Bryan
Bryan
. . . Probably the only thing I could do is stick a bigger tire on for more stopping power, not too sure how that would work with abs? . . .
The ABS would be fine. It does not know why the brakes are locking, only that they are locking.
. . . Now, if you're road racing and doing alot of braking, brake fade will probably occur. So, you need to get rid of heat and need an upgraded system. . . .
Originally Posted by Silver-Bolt
You need to get out and drive fast. The L brakes suck in their stock form. Add bigger wheels and the problems get worse. Everybody is willing to dig deep and spend money to go faster and make more power. Very few invest properly into making it safer. Very few also realize that increased braking performance will also make you faster.
Bryan
