Truck leans
Originally Posted by Rob_02Lightning
Maybe it's Gators old truck
His two little friends (and I do use the word EXTREMELY LOSELY) seem to have a habbit of wearing out the pass side suspension for some reason
Originally Posted by FunFord
My truck sits 1/2'' lower on the passanger side in the rear
Just like the title says. My truck sits 1/2'' lower on the passanger side in the rear, and a 1/4'' lower in the front on the passanger side. Its noticeable to me beacuse I have measured it and I know its off. What could I check for, to find the problem? thanks!
You could try Airlift Bags (Rear Suspension) They will help level it out and when you have loads just not extreamly heavy loads like above you can increase the preasure so you don't sag like above... BUT you might want to check and see if anything in the rear is tweaked from racing. That has been known to happen from time to time...
Later
