Big cam built motor guys.....
Originally Posted by Casey02L
Hummm; well I had the shift point set to 5700 and the rev limiter set to 6100 and it was hitting the rev limiter
Guess I'll try to log where it's actually shifting at, and move the limiter up some more.
If you're talking low gear that's pretty common. With the acceleration rate in first gear by the time the trans completes the gear change you can be on the limiter. I know a guy that has his 1-2 shift set at 5200 rpms; it still hits 57-5800 rpms by the time it shifts.
Jody
Jody
Jody
But damn does this setup with the big Comp Cams pull good up top
