What do you know about Sean Hyland Built Engines?
I was thinking about buying one of his Built long blocks w\ 2770 cams and ported heads... Does anyone have one of these engines in their trucks?? If so, how do you like it? Do they build a good 5.4L Lightning motor??
PS, I am debating between Sean Hyland and Johnny Lightning... I am buying it tomorrow!
Originally Posted by koopdaddy
I couldn't find any Sean Hyland problems, that is why I posted?? So JLP is the way to go then..
Sean Hylands motor was the worst sounding piece I've ever heard in my life. You will think your truck is a diesel from the piston slap. The last one I heard didn't last two months and they were in court last I heard as SHM would not stand behind it. No way for any amount of money.
Jody
Save yourself time and money and don't buy one of his engines. MY SHM engine lasted about 30 seconds on first startup and broke the the cam keys out and got all out of time , i then put stock cams in got it running after 75 miles it sounded like a powerstroke diesel. wrist pins were shot on 3 cylinders because they used cheap wristpins that weren't polished ,stock wrist pins have way more of a polish then these had it just ate the pistons up. If your heart is set on a new built go with one of the big 3or5 names out there. One of the best ford engine builders in Phoenix and close to home , he is the one that fixed my engine and would recommend him ,Brian Duffee www.duffeemotorsports.com. I just got done installing 2 weeks ago ,my repaired SHM, new cp pistons ,crank rebalanced, with flywheel and harmonic bal. basically a total rebuild , ported and flowed heads, by Duffee bigger valves, comp cams. engine is super quiet, only noise i hear are the belts whirring around. I am very pleased with his work, he has a total machine shop and can do anything you want , pays allot of attention to details. I have a stock lightning engine for sale has only 9000 miles on it ,I was going back totally stock because of the frustrations ,but decided to give it one more shot. Make an excellent built motor , standard bore. Email me at skainrath@hotmail.com for more info. Oh yeah SHM still owes me about $2500
