SYCLONE????
If they're both stock, the Syclone should win out. Put a chip and air filter kit on the Lightning, however, and it'll be a close race and could go either way.
I owned a '91 Syclone for 6 years and have owned my '99 Lightning for 6 months, so I've had a bit of experience with both. Two fun trucks, that's for sure!
Mike Philpott
Orlando, FL
'99.5 Black Lightning
SVT #2190 - Build Date 6/9/99
NLOC #361
6 CD Changer, Class 3 Hitch, A.R.E. LSII Lid, BedRug Liner, Invinca-Shield/3M Scotchcal protective film, Wyldman's Clear Lexan Fog Light Covers, 16% Window Tint, LoJack, Val-1, Sal's PSP Chip & Air Filter Kit
Mike Philpott
Orlando, FL
NLOC #361
Hey LoCoX..
Do us a favor, we have a NO CAP RULE here, it is considered YELLING!
No flame intended! Just a reminder
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover, LoJack, Valentine 1, Mobil 1
Superchip, Water Wetter, Phantom Boost Gauge
Best ET to date-13.54 @101.51MPH--10/29/99
Best MPH to date-102.33
NEWEST ADD.--16" SNOW TIRES
SuperChip out for now
'98 Red Lincoln Continental
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
Its nothing to whine about but, i'll show u some respect and stop the caps, but its a hard habit to break....no beef!
1997 F150 Lariat supercab; two 12 inch mtx 7000 subs and 700 what amp; cherrybombs and alot of chicks...lol
Goal in life: is to own a Lightning
[This message has been edited by LoCoX LiGhTnInG (edited 01-12-2000).]
Sy,no doubt about it. Stock they will run 0-60 under 5 secs.(light weight+awd is a killer combo,wish Ford would have given the L's awd) 1/4 mile range from high 11's to low 13's.But with a mod or two the Sy will pull low 11's consistantly.The high end on the other hand...Well a Sy won't reach 140 w/o the mods(even then I'm skeptical),it's turbo shuts down @ 120.Both are awesome auto's,but like has been said before "apples and oranges".
Brett the "Hitman"
99.5 Lightning(stock...for now)
Brett the "Hitman"
Out of the box a Syclone will run 13.80s, but only at about 96 mph (hard to turn that AWD at higher rpms). Put a bag of ice on the intercooler and it'll crack out 13.20s. Still all stock. Decent exhaust and a fish tank bleeder valve and they'll run 12.80s.
But they're fragile, fragile, fragile - the AWD is very problematic. You can't tow anything with one. They're basically worthless as a truck. They were built with one thing in mind - Mind bending hole shots and brutal stoplight acceleration.
Later!
Jeff S.
http://nloc.org
Later!
Jeff S.
http://nloc.org
4wd there is a mechanical link between the front and rear axles, most curent systems lock this link so both turn at the same speed. Older ones (full time 4wd) would use a differential between the two axels, but you could switch to "LOC". Awd uses a viscous coupling (some radiator fans use viscus couplings) the transfer power to each axle. Each axle can turn independant of the other to some degree, plus it is full time you can't switch to 2wd.
