ported blower questions
I installed a ported blower on saturday. First thing is the noise is makes. It almost sounds like a bad bearing in the backside of the blower. YOu can hear it in the video below. It sounds worse in the morning after sitting overnight. The noise goes away after the truck warms up though. Also the boost is very inconsistent. I have gotten on it a few times and it has hit 15-16psi which would be normal considering the 2psi increase claim. Other times its only going to 10 psi. I emailed steig and I guess they are at sema so no reply yet. Just wondering if anyone has had a similar problem and can point me in some direction to remedy the problem. Thanks for any help.
http://www.racers-edge.us/noise.mov 4mb quicktime of the noise.
Had mine ported Sept. 04. I don't recall hearing that sound until outside temps were in the low 60's and below. It would pretty much just happen on morning startups during warmup idle and for the first few minutes of driving when ever the rpm would pass through the 1100-1400 range. Eventually I called them about it and was told that it was probably rotor to case contact and if I brought it in they would clearance the rotors for me. Finally did that at the end of March or so. Could have sworn that I heard it once or twice again after reinstallation but then I had to wait for morning temps to drop again. We have had enough cold mornings this fall that I would say it is fixed because I have not heard it since. And yes it was the same sound I can hear in your video.
As far as your inconsistent boost I would check the boost actuator mounting bolts if you have not already and adjust it. Search for how to.
Good luck
JJ
Good luck
JJ
Guy's if you send just your case out to be ported you need to add some grease to the bearings before you put it back together. Also take a good look at the bearing to make sure they don't have any crud in them. The rear bearings take about 1 cc of grease make sure not to over load them also too much grease generates more heat. By the way when you put the rotor back in there should be .003" of clearance between the rotor pack and case. Use a long set of feeler gages to set the clearance. One other thing make sure you follow the torque sequence when tightening the supercharger back down. If you don't it could distort the case and give you less clearance and wipe your rotor out!
Hope this help,
God Bless,
Suavy
Hope this help,
God Bless,
Suavy
Originally Posted by Fast95Z
Ive adjusted the boost actuator a few times now and no change in the inconsistant boost. Also I got the blower complete from steig not just a ported case. It was all preassembled.
Make sure to check your vacuum lines that you removed during the SC job. Look for cracks or dry rotting. I blew a head on the dyno due to a dry rotted brake booster vacuum line before.
Hope this helps,
Peace,
Suavy
I messed with the actuator some more and there is no change. From a slow roll and punching it boost will SLOWLY go to 15psi then the truck will shift and it drops to 10psi then SLOWLY work its way back up. I have the boost bypass done also. Is it possibly belt slip? It's only a 4lb lower. I haven't heard back from Bob yet. Before the ported blower it held a very solid 12psi.
95z, we talked a bit over on NLOC. i have the new "stage III" also. i did put my 4lb pulley on and could not hear the same noise or anything akin to cavitation. then again it was only on for 2 days then removed for towing when i go back down to 2lb pulley. if you need any close up pics of where all the vacuum lines go, let me know-- i took a bunch of pics and i'm about to delete them from my cam, but can post up to my website for you to grab. LMK i'm sure bob will take care of you if it's a problem with the blower.
Before you remove the blower. Loosen the upper intake plenum, retorque the rear bolts first, then the front bolts. I bet this will stop the noise. It is very rare that the bearing go bad after a port job.
Also, try pulling the vaccum source to the boost actuator, and see if the noise goes away.
-Mike
-Mike
