Need Help Engine Popped This Morning
Originally Posted by svtjulian
Yeah it is a spark plug. The coil plastic broke off were the bolt holds it on. I got the extented warranty. Has anyone one had the same problem? What were your experience with the dealer??
Originally Posted by Rob_02Lightning
I DEF think you should get a set of used factory plugs and put them in
and crazy enough, if you can re-install the factory cat back, I WOULD
As said Ford WILL void the wrrnty and fk you if they find ANY mods on the truck, even if we know they dont play a part.
So sorry, Good luck Bro
You need to have the stock plugs in as they will blame you or who ever put in the densos for a faulty install. Put the catback back on as well the closer to stock the better chance you have. Extended warrantee companys are not known for being to easy to deal with, This will cost them money and they will fight you over it.
Do not give them a chance. Go in with info about how many have blown both Lightnings and regular F150s.
Good luck
