Whipple 3 Vs. Turbo
Old 11-14-2005 | 03:01 PM
Rob_02Lightning's Avatar
Good point Jody, and your right
NEVER MIND
Old 11-14-2005 | 03:43 PM
YUL LUZ's Avatar
So in order to lift a head, it means there has to be uncontolable combustion? How does that work? How do you stop it? Does a S/C or Turbo increase/decrease the risk or are they the same risk?
Old 11-14-2005 | 05:10 PM
liteitup's Avatar
more than you probably wanted to know
http://www.streetrodstuff.com/Articl...tion/index.php
Old 11-14-2005 | 08:42 PM
Bad as L's Avatar
Originally Posted by wydopnthrtl
Dale was that on a caged version of the lower pulley?
Rich
Hi Rich
No....My aftermarket caged pulley didn't last too long before it made its way to the garbage can...and yes I'm serious. I used and 8lb JLP or PSP not sure which....I got it used.
Dale
Old 11-17-2005 | 08:13 PM
Suavy's Avatar
Originally Posted by Bad as L
The magnum is a 112 cube blower....and on a short dyno pull that doesn't count. Sal on the the other hand does count. I don't think he made it past 300 feet down the 1/4 without busting something in the drive...he will have to correct me on that but it was a nightmare for him.
Dale
Bad, yes we did make that kind of boost on the dyno but we also did it on the track at Lapeer Dragway but lifted both heads doing it 2 years ago.
Peace,
Suavy
Old 11-17-2005 | 08:37 PM
Bad as L's Avatar
Peace,
Suavy
Suavy
I'm not questioning wether you made that kind of boost...I'm sure you did but my point is that on a 112 cube Eaton it just isn't stressing the 8 rib drive belt like a larger blower or in the case of the 3.3 whipple (almost 202 cubes) almost twice as big.
I'm questioning the drive system on a big blower at high boost, not the high boost by itself.
Dale
Quick Reply: Whipple 3 Vs. Turbo
