head and cam set up
HI!... I'm running FOX LAKE STAGE II (CNC ported) cylinder heads with :
- CROWER "BEEHIVE" springs.
- CROWER retainers.
- COMP-CAMS custom ground 0.599/0.599 lift, 234/234 duration.
- MANGANESE BRONZE guides
- MODMAX valve seals.
- FERREA S/S one piece sodium filled oversized undercut valves.
- Hardened valve seats.
- New stock roller followers.
- New stock hydraulic lifters.
- CROWER retainers.
I have what were experimental cams at the time, since I was one of the first to do cams on my motor. Mine are basically a Crower stage 3 cam with some of the duration taken out of them. My heads are just hand ported, and gasket matched. Along with bigger valves and crower springs.
There have been a lot of advancement in the porting of the heads since mine were done, but I am happy with my setup.
Thanks Bob
