Built motor guys
Built motor guys
Does anyone have a start up issue when hot? I have to give the truck about 1/16 throttle to get it to fire up then its all fine. Also My truck idles a lot rougher sometimes stalling when i put my 2.8 upper on compared to my 3.5 I figure this is due to adding more RPMS to the blower @ idle so it is moving more air making it not idle smooth?
I do from time to time but I'm runing stage 3 Crower cams on a daily driver. I use a 2.69 upper and and a 10 lb lower.
Peace,
Suavy
ok next small problem.....my truck doesnt like to idle in park. it will idle fine in drive but put in P or N and it will chop for a sec or two and then just die. Checked the IAC valve and its good. Not sure on this one
Originally Posted by Casey02L
Single Blade Throttle Body? If so you might try moving the adjustment screw to open it up a little more. I found out that fixed a lot with mine. Basically were out of the range of the IAC valve with cams and such done. You will have to adj it back and forth till you find the sweet spot.
I have read by some people that you should unplug the IAC and then set the tb screw to where the truck will somewhat idle with it unpluged then plug it back in and its suppose to idle smoother?
