Tossing around the thought of Nitrous...
Well, im thinking about adding just a small shot of nitrous for next year, just to see what it will do for the truck. My current set up is:
6lb lower
Apten port
E-Fan
C&L Upper/Accufab Throttle body
Maf-x
Jlp Ram air
FTVB
JLP long bars/28"Hoosiers or Nitto Drags on the Street wheels
JDM Long tubes/high-flows/Silver Bullet
Anyhow, beings im making about 18psi, i figure I am already pushing my luck. I was thinking along the lines of a 25 or 35 shot. I think that would make for quite a lethal combo if I could keep the stock block together. I will also be adding a Stall converter shortly, so I am figuring 12.0's/11.9's all S/c. Am i off in thinking maybe 11.6's are possible w/ a little spray? Well just curious to what everyone thinks. I'm tossing around some setup ideas.
6lb lower
Apten port
E-Fan
Maf-x
Jlp Ram air
FTVB
I'm in the same boat as you. I have the same mods as you minus the C&L which I already have on order. I also ordered a converter that will be going in on Friday. I put a wet kit on this past weekend. Haven't had a chance to get to the track with it yet. It's a 50 shot and I did a 1st gear run with and without the nitrous I couldn't even tell the difference.
