most boost ever made on a K.B.
Old 11-30-2005 | 11:44 AM
RAMAIRSVT's Avatar
Question, What is the most boost anyone has made on a K.B. in a Lightning;
I just lifted a head; and right before it happend my gage showed almost right at 28.
#10JLP lower, 2.75 kb upper and 0 belt slip, the temp was 43f. Is this possible to make 28 psi?
Old 11-30-2005 | 11:53 AM
LatemodelRacer2's Avatar
do yuo have headwork?
Old 11-30-2005 | 11:57 AM
RAMAIRSVT's Avatar
Ported & polished sage two cams; built & all boltons
33k on the clock, but i have never cleaned my intercooler; could that caus more back pres?
Old 11-30-2005 | 12:03 PM
NoSuprise's Avatar
Double check your gauge for calibration.
My new AutoMeter boost gauge was reading 4-5 pis high at that level.
I could see 30# sometimes.
The new replacement reads mid 20's now.
NoSurprise
Old 11-30-2005 | 12:51 PM
RAMAIRSVT's Avatar
NoSurprise
So maybe its ok at lower boost but gets off the higher it goes?
Old 11-30-2005 | 01:56 PM
JeffsLightning's Avatar
Arp head bolts?
Old 11-30-2005 | 02:11 PM
Skank Dog's Avatar
Originally Posted by JeffsLightning
Arp head bolts?
Bingo!! If you dont have ARP head studs,chances are pretty good thats why you lifted a head. The stock torque to yield bolts just arent strong enough
for near that boost level, they will stretch. The ARP's are a PITA to install though.
I did my ARP's with the motor still in the truck that's why it was such a PITA.
With the motor out,no big deal.
Old 11-30-2005 | 02:18 PM
NoSuprise's Avatar
The error was progressive.
The error showed up in vaccum readings too.
With cnc heads & stage 111 cams I had 16-18 inchs vaccum at idle.
New gauge shows 11-13 at idle.
NoSurprise
TheGoaT's Avatar
He has the studs. Seriously guys I doubt there is a built motor combo out there that doesnt have the studs.
Old 11-30-2005 | 02:24 PM
NoSuprise's Avatar
But are the studs the new ARP 2000?
I've lefted the heads with the old style ARPs at 75 foot #s torque.
Old 11-30-2005 | 02:42 PM
Skank Dog's Avatar
LOL! You wouldnt think so, but Ive seen it first hand with a guy here in town.
Built bottom end,fox lake valves,ported heads,10 lb. pulley and freakin' stock head bolts. I tried to tell him,but he wasnt havin' none of it. He hasnt had any problems yet,just a matter of time though.
Old 11-30-2005 | 03:21 PM
dirtchicken's Avatar
It doesn't matter if you have studs or the stock bolts. If you have detonation that is bad enough the head will still lift.
Old 11-30-2005 | 03:51 PM
2bscrewed's Avatar
How do you tell the difference between the old studs and the 2000's. I have lifted my heads twice with ARP studs. I don't know which ones they are though. I paid $219 for them. I was just told by Dante that he has some special ARP studs that cost $550 but he hasn't had a problem with his hi boost trucks lifting heads ever since he started using them. That is pretty steep for studs, but if it will keep me from pulling the motor a 3rd time I will pay it.
Old 11-30-2005 | 06:36 PM
NoSuprise's Avatar
I was going to say the price will tell you. Over $400 = new 2000.
Old 11-30-2005 | 07:59 PM
Casey02L's Avatar
Something isn't right there; probably the guage.
Quick Reply: most boost ever made on a K.B.
