Running Lean!
Running Lean!
My truck started running lean at WOT all of the sudden (like 15.1)!
I got my tune from PSP everything worked fine for a couple of months. I have the Excalibrator II, so I was able to set the air/fuel up to 14% richer at WOT in the tune.
This did nothing!
I think the tune is fine, but my truck no longer knows when it's at WOT. I checked the TPS and it's at .992v closed and 4.3v wide open (using a Billet-Flow throttle body).
It is much cooler outside, and I have upgraded to a LFP heat exchanger and a JLP intercooler tank. My IAT temps are super low. Would the cooler, denser air cause this?
Help!
This did nothing!
Help!
Where is the relay located?
I forgot to mention that I have a Autometer fuel pressure guage. At idle, I see 37psi, and at WOT, I see 54psi. That has been unchanged from the start. I can see on the fuel pressure guage that something kicks in at 3/4 throttle that immediately adds 10psi.
I have a single Bosch 255lph fuel pump. I would like to go larger, 400-500 lph when I go to the built engine. What about a exterior pump (not in tank). That would make servicing a lot easier.
I have an AEM wideband. I feel confident that it works correctly due to the idle A/F readings are stable and normal (14.6 - 14.7).
