Weird Noise
Weird Noise
Guys, My Truck has been making a weird noise for quite some time now. It happens right after startup and lasts for about 4 or so minutes. I have already installed Metco Idlers and replaced the remaining idlers with new factory ones. Should I replace the belt as well? It almost sounds like a clicking noise. Im all out of ideas and it is driving me crazy. Thanks in advance for the help, Kyle
BTW, The Truck is a stock 99L
Originally Posted by Kyle
Thanks for the help. Is that a major repair? Im just a beginner when it comes to these trucks.
You gotta pull all the idlers, pulley, harmonic balancer, fan, and the front plate on the motor. Best way to tell is get yourself a mechanics stethescope. When you hear the noise try to track it down. If it's the timing chain tensioner then you will hear it right at the front of the valve cover, down about an inch on the front plate.
I changed mine 3 times. Still had the damn noise. If you replace them, get the metal ones, not the new plastic ones and replace the guides too while you're in there.
