Attn Gregg Evans.. HELP!
I have an issue with my Monster Box. It's 7 months old with 7,000 miles on it.
Here is the issue. During coasting situations ( fully off the gas ) in both 2nd and 3rd gears the rpms will drop to idle like it slips in neutral. It allways happens in 2nd gear no matter what but if I shut off the OD it acts normal in 3rd gear! Turn the OD back on and it drops rpms as soon as you let off the gas.
I know it's under warrenty still but I'd to know what's going on with my transmission. Is this something I can swap out myself? I have the skills to replace any and all things inside the pan.
Any and all help would be great.
Thanks,
Jason.
EDIT: After a quick search I found someone with a similar issue. Is this normal and just more noticable with a big stall? If it is..why does 2nd gear not get affected by turning off the OD like 3rd gear does..PLEASE explain!
Thanks,
Jason.
