Whooping sound in intake tract
Hey Guys it bee a while since I have posted,
I have a problem with my L. It runs great but when it is idling and until about a 1000 rpm's I hear a whooping sound in the intake tract. Its hard to describle it, it is not constant it come and go. The truck runs fine otherwise. But I know that this sound should not be ther. It realy sounds like someone who has a whooping caugh that hollow like sound, really weird If someone has ever had this problem please help me to solve it, HELP
I pulled this pic from Rob02's lightning gallary. (hope you don't mind bud!)
Its very easy. Two small bolt, I believe 7 or 8 mm, and one connection. Just keep the gasket clean, or get a new one, and I usually put a little grease back on the gasket to help seal it. Pull the IAC off. Spray with a little brake or electric motor cleaner, work shuttle valve back and forth. Spray again, wipe down any residue, and reinstall. Or buy a new one.
One side note....see how the plug connection comes out at a 90 degree angle, and faces down? I bought a new one, and it comes straight out. It is too tight on the wires...I'm going to see if the have the correct one still in stock, or if thats an updated part number.
