Hungry for more valvespring info: Read this!
#46
#47
I'm just glad all of this information came to my attention BEFORE my engine was done. To continue the learning process can you explain about preloading the lifters in the modular heads? I know how to do it on pushrods but I am not aware of any adjustments on the mod heads. If you could elaborate on what they should be loaded to also that would be helpful. I know you don't want to tell all of your secrets on here so if you can't that's fine. I want to make sure I have full understanding about what needs to be done to make my truck run it's absolute best when it's done. Much thought and personal debate have gone into trying to decide on cams and so on with my upcoming head work and I want to be as informed as I possibly can be in order to make the most intelligent decisions I can to ensure nothing is left to chance. 3K is looking more like a bargain for heads to me now, whether it's due to the lack of information available from the other head builders making the JDM ones look much better or just the fact that they ARE better. My L is a DD and will remain so for a while to come so reliability is important to me. I am in no way afraid to spend money but I do want to make sure that if I spend an extra 500 then I am getting 500 worth of extra performance or whatever, you know what I mean.
I will agree that this has been one of the most informative and interesting threads I have ever read.
#48
Originally Posted by fade 2 black
I have been in and around L's for five years now and I have learned a great deal along the way. I have never made a purchase from JDM, I had basically come to the conclusion that they were just overpriced for what they sold compared to all the others. After reading and being involved in this thread I now realize that I have been very wrong in my thinking. It is so amazingly refreshing to see a vendor on one of these sites explaining not only his product but how he arrived at his products. Thanks for all the info and time Jim.
I've been friends with Jim's, JDM, and all their customers since the day I bought my Lightning, (over 4 years now) and although we were always good friends I too never did much business because I always found what I thought was a better deal elsewhere. When I look back at the 5 diff Chips I've bought, 7 Upper Pulleys, 5 Lower pulleys, 2 built motors, 2 ported eatons, 4 differant air systems, 3 cat backs, bla bla bla
BELIEVE ME WHEN I TELL YOU I COULD HAVE SAVED 15K BY GOING THERE DAY ONE.
Some get upset because Jim does have a certain set up he insist your truck has to perform correctly, but man I can not tell you how frigging amazing my Lightning drives these days. To be able to drive around with over 550 HP 24/7
"on my winter tune", 580 and over 600HP for the warmer weather and racing, is simply a dream come true for me. What amazes me daily is the tuning, the drivability, and the throttle response, not to mention amazing gas mileage, (it's actually getting better mpg around the street than my v-6 Mitsu).
My L needs each and every piece it now has on it, and there's a lot on it
But the icing on the cake was the things he fixed I didnt know were broke, the changes he made I didnt ask for, (or get charged for in some cases), the attention to detail and workmanship truly is second to none. Add to that the time, effort, and knowledge he's put into his motor program, the results he's getting out of them on the 1320 (and longevity). And belive me when I tell from experience, IT'S CHEAPER IN THE LONG RUN
I could have save A TON by doing it once, and doing it right
#49
#50
BTW....Jim....you wanna throw a set of them springs in my truck when it comes in for its next tune in a couple weeks? Pretty please!!!!
#51
Originally Posted by netoje
...all this information is priceless. I would probably have never learned this without reading it here. One of the finest post in f150online in a while!!
-OJ
-OJ
We spend about 8 hours on each head during our assembly process. First thing is we get the heads back from being CNC'd. Then we use another machine to do the valve job its called certy, what it does is allow you to do each valve at exactly the same depth during the process of the 3 angle valve job. Each angle of the valve job are made exact using this machine. This way each valve stem will arrive at the same height when you set the valve in the guide. This process is done after you determine the proper height of valve stem for your lifter preload.
For those of you who want to check lifter preload, what you have to do is make sure your cam is installed in the head with out cam followers or lifters. Then you get an old lifter, there is a retainer on the top of the lifter that hold plunger in place. You pop the retainer off, pull the plunger out and remove the spring that is inside the lifter. Then you put the plunger back in the lifter with out the spring. This will give you full collapsed travel. Now you stick that lifter in your lifter hole, rotate the cam to the back side of the lobe, The back side of the cam is the side without the lobe. At this point you reinstall your cam follower where you just installed your lifter and get your feeler gauges out and make sure you have .050" clearance between the backside of the cam and the top of the roller on the cam follower. If you dont see .050" the only way to gain this clearance is to tip the valve. That means the top of the valve must be cut down. This is the reason why we use the Certy machine to make sure every one is within .001-.002." A good certy machine will run you $120,000! Factory Ford is around .020"-.025" clearance. I have seen some heads from other manufacturers that have had 0 clearance to only .010" clearance and some where the valve was actually held off the seat. A good range is between .040" and .055"
Hope this helps, I have enjoyed posting this hopefully next season we'll see alot more L's running faster out there because of this information!
Jim@JDM
#54
#57
#59
We tested several valve springs and found the following:
Stock springs:
74.5# @ 1.640 (VC)
184.5# @ 1.090 (VO) (.550” lift)
Comp Cams PN# 26113-16
80# @ 1.64” (VC)
183# @ 1.09 (VO)
Crowler
90# @ 1.640” (VC)
242# @ 1.090” VO)
Manley
95# @ 1.640” (VC)
240# @ 1.090” (VO)
Note: Comp Cam springs are really not much stronger then stock.
Charles
Stock springs:
74.5# @ 1.640 (VC)
80# @ 1.64” (VC)
183# @ 1.09 (VO)
Crowler
90# @ 1.640” (VC)
242# @ 1.090” VO)
Manley
95# @ 1.640” (VC)
240# @ 1.090” (VO)
Charles
