first 5.4 ceramic lightining?
has your friend had any trouble? the shop has coated,the bores, pistons,heads,valves,they say it will give me more power,less heat! all this has been with a lower engine rebuild kit i colleted from JDM. i hope this will give me a nice strong engine. getin fed up with chaging engines as this will be number 3
This might cause a problem bedding down the rings.
Anyway you don't want to keep swapping motors but you could patent a quick release engine kit
And you beter watch out cos there's two JDM powered 'L's looking to fry your *** and there both RED.
on
1 Post
has any of you lads tryed useing ceramics in your engines? im just having one built over here in the uk, done by the same people the do f1 engines. lookin forward to see how it performs
