The DG air dam is pimpy!
Originally Posted by Tim Skelton
You guys should have bought earlier. They were a flop. It looks like SMC, the OEM, has finally discontinued them also.
I picked up a spare before Tire Rack shelved them.
Anxiously awaiting some daytime pics of your beast's new look.
on
1 Post
Originally Posted by Ricki F-150
. . . maybe catch a few lumps & bumps. . .
. . . But what is a Porter Cable . . .
In less than 24 hours, I have scraped the hell out of
the underside. But you can't see it unless you are kneeling down.
and not hit everything. Speed bumps KILL me. My Oil Pan scrubs when
I go in for an alignment ...
But man this S.O.B. can corner .... < grin >
Cliff
PS... and Black doesn't show "Cone Flesh" as much as the Red does ... < grin >
Originally Posted by MHMCGILL
I might suggest some Griots under carriage spray for the wheel wells. It make the rubber/plastic black again instead of grey. Buy it by the gallon. You won't regret it.
BTW I liked your truck better before, but I didn't pay for it or drive it so, enjoy.
on
1 Post
Here are a couple of daylight shots. I took them on the way out the door this morning. They suck and the truck is dirty as hell. It's an embarassment -- like answering the door in a stained t-shirt, I tell ya.
The light is all wrong (to the back of the truck). The first one is brightened so it's not all black. The second one has been Photoshopped with the ducts black and the HE darkened to simulate the effect of the black grill over it. The wheels turned make the dam look off center. It's not.
That is quite a change and it seems to work well with the wheels. When you add the grills, this will give a much more integrated look to the front end. I'm sure it will look great when its all done.
How was the Sir Mike pan install? I had to do a ton of modifications on mine to make it fit?
TB
TB
on
1 Post
Originally Posted by TrackBeast
. . . How was the Sir Mike pan install? I had to do a ton of modifications on mine to make it fit? . . .
The bodywork was done by a former Sir Mike employee, so it fits about as well as any I've seen. I don't like the gaps between the pan and end caps. I'm looking for some thin c-channel moulding or seam molding to fill the gap.
Tb
My pan was installed by a fabricator and they had to
add metal to properly fit the gaps. A brace was added to the caps to tighten
them in. Needless to say that they basically completely rebuilt it and the
install cost me a bundle. It now fits perfectly but has little in common with
the original.
Tb
the original.
Tb
extra dollars but the final product looked great. (Til I backed into the
pole at LightningFest in front of like 40 people!) Now the right side is
a tad off ... < grin >
