Yes or NO, can you run the Kenny Brown X-factor without modification w/ JLP lift bars
Without modifying the Lift bars, the Front Lift bar mounting flange, or the Kenny Brown X-factor brace, Can you mount the X-factor or does it interfere with the Front Frame Attachment flange for the lift bars?
I recall someone spent some serious $$$ modifying it to fit with JDM bars, but I'm not sure if they are the same length. I thought one was 58" and the other 54", I could be mistaken.
Does anyone have pictures of what exact holes the X-factor uses to mount in the rear?
Originally Posted by speedraisor
menace- not sure if you already have the brace or not, but Kenny Brown is no longer in business as of late Oct...
huh... I had no idea. RPMoutlet stills list them on their site.
(I know, I'd never buy anything from there, but I saw the picture on their site)
Speedraisor where are you at?
on
on
1 Post
Out of all of the stuff that I have piled up to install, including engine mods, the X-Factor is the thing that I am most looking forward to trying out.
Despite having tweaked the suspension to its limits, at least the stock layout, I am still not satisfied with the truck under hard cornering. Feels a little vague and sluggish. I know the steering setup is k-rap, but the turn-in feels a little wierd - crisp initial turn-in (I am running 2 degrees of camber), then it feels like the chassis loads up or something.
Having lived with the thing for a while now, Al, do you notice any difference in mid-turn stability?
on
