Anybody need something water jetted?
I got a new job working a water jet machine. For those who don't know what this is, it's a machine that can cut a 6" piece of steel with 60,000 psi of water and granite mixture. I've worked with mainly stainless steel and aluminum and damn does it do a great job. I can cut basically anything you want. If you are interested PM me and let me know and I'll let you know if it's possible. I should have Rhino or some other Auto-Cad program uploaded here soon, so with that I can design anything you want.
Kurt
Kurt
Kurt
Kurt
Originally Posted by Ruslow
I have many items cut out on a jet but I also have to go back and make the edges flat[it cuts on a taper[all do]].and the precision is not there.If you are after really close tolerances use a laser and the finish is nicer,But for many things the jet works ok.STan
For light sheet metal the laser is the faster, more efficient and therefore cheaper way to go. But when you start going to the thicker materials, 3/8+, most lasers won't be able to do a good job and the waterjet becomes the better alternative. So if you are doing a job with a mixture of thin and thick materials the water jet can do them all with one machine.
RUSLOW I'm not sure what your talking about. I have cut 1/2 stainless steel with a perfect edge. maybe your receiving a taper because of the acad setup or because your speed and acceleration is to fast. I need to find a way to get pics up here to show you.
svtandy...and your point is?
A laser is for the most part cleaner, but if you have a state of the art WJ and all is good it is a hard call...
thanks for the back-up Dbl-G and silver2000svt. For those who want to know, im located in tampa fl. my email is thehurt27@aol.com give me a shout if anyone is interested.
kurt
kurt
