test of more HP pix
test of more HP pix
This is a test and if it doesn't work, well that means it didn't work....hunh?
{IMG)http://www.zing.com/album/pictures.html?id=4294556509&p=4290964958(/IMG)
I must be doing something wrong.....might have something to do with a reference to html....will try to change it to UBB code
[This message has been edited by blackbolt (edited 04-24-2000).]
[This message has been edited by blackbolt (edited 04-25-2000).]
Most common error is spaces, looks like you tried to point to the page the photo was on rather then the photo itself. Next time right click on the photo choose properties, then select all of URL that is listed and right click choose copy then paste it between the img tags in your case it would have been (img)http://www.zing.com/picture/p3bacaff13a7fd7f83a3b9cf188518bda/ffc2edde.jpg(/img)
Use the correct brackets and the photo will appeare rather than the path....
It takes us all a couple tries to get it right
Doug
[This message has been edited by Silver_2000_! (edited 04-24-2000).]
Doug
4D THNDR -
I thought that was it also, but discovered that it was not a jpg. Like Doug said, it appears Blackbolt got the properties information on the page and not the picture.
Is that 25rwhp or at the crank. This could be the cheapest/best mod yet. If I use two in series, can I get 50hp?
[This message has been edited by sixpipes (edited 04-24-2000).]
