NEW BEST W/O N.O.S.
NEW BEST W/O N.O.S.
Went to the track Saturday. Me and about a million other cars. Only got three passes in. Found out on the first pass nitrous bottle was empty. So I decided to run without it. Had two passes only .002 difference in E.T.
Here's the best one:
.893 Reaction
1.771 60 Ft.
5.161 330 Ft.
8.016 1/8 E.T.
85.08 1/8 MPH
10.497 1000 Ft.
12.612 1/4 E.T.
106.83 1/4 MPH
This was the first day with the new M/T Street ET's. They seem to work as good as the old slicks. The weather was perfect clear skies and mid 50's. Also long cool down time in between runs helped alot.
Hopefully the headers will be on for test and tune Wednesday. And the bottle will be full.
Running out of time before St. Louis.
HIGH RISK
.893 Reaction
1.771 60 Ft.
5.161 330 Ft.
8.016 1/8 E.T.
85.08 1/8 MPH
10.497 1000 Ft.
12.612 1/4 E.T.
106.83 1/4 MPH
HIGH RISK
O.K.
HIGH RISK
'99 Lightning
Super chip
Pro-m 80mm
4.10 gear ratio
Level 10 Convertor
Level 10 Shift Kit
Flex-a-lite dual 12"
electric fans
3-6" Flex-a-lite
electric fans on I.C.
Manual pump switch for
I.C. pump
Mickey Thompson
10"x26"x16" slicks
N.O.S. Dry kit
HIGH RISK
- '99 Lightning
- Superchip
- Pro-M 80mm M.A.F.
- Level 10 shift kit
- Level 10 Torque Con.
- 4.10 gear
- 2-10" rad.fans
- 3-6" I.C. fans
- Switch to run I.C. pump manually
- N.O.S. Dry shot (80hp)
-12.29 w/bottle
-12.61 w/o bottle
HIGH RISK
'99 Lightning
Super chip
Pro-m 80mm
4.10 gear ratio
Level 10 Convertor
Level 10 Shift Kit
electric fans
3-6" Flex-a-lite
I.C. pump
Mickey Thompson
10"x26"x16" slicks
N.O.S. Dry kit
HIGH RISK
- '99 Lightning
- Superchip
- Pro-M 80mm M.A.F.
- 4.10 gear
- 2-10" rad.fans
- 3-6" I.C. fans
-12.29 w/bottle
-12.61 w/o bottle
NICE PASS
Are you letting it go into od, or high rpm in 3rd?
I let mine go into od. 12.89@ 107.62
I think I'll need a stall converter next,to get those awesome 60ft. My 60's are still high 1.89/1.93
Hope to go to next race!!
JIGAWATT SVT#2698
N.L.O.C. Member
KSP 4" Filter Kit
4:10's
Bassani kit
TransGo shift kit
AIM 2 inch drop shackle
[This message has been edited by JIGAWATT (edited 04-24-2000).]
JIGAWATT SVT#2698
N.L.O.C. Member
KSP 4" Filter Kit
4:10's
Bassani kit
TransGo shift kit
Jigawatt,
I run with overdrive shut off. Tried turning it back on at the end and went slower. I am in a bad situation going through the traps at 5700 rpms. I would like to have a little less gear or a taller tire.
Sorry about the double sig. tryed to update it and made the super sig. I've heard people get yelled at for too long a sig.
HIGH RISK
HIGH RISK
Bob
Since I have no other way to reach you and you are back to posting here is some information for you. I shared my source for the 15" wheels with your bud "Mike". I am suppose to get one maybe two wheels from the supplier this next week. That being the case my friend at his tool shop will index them for 5x1.35mm ( hey I make it sound easy but there are other things that will need to be done too.). Sure would be nice to have a choice over your effective gear ratio,tire width and compound. It should be interesting if it works, so much for the guru's that say you can't fit a 15 inch wheel. Bob, send me an e-mail.
BABolt
SVT#290
BABolt
SVT#290
No Bob, they get yelled at with a long signature that they use over and over and over..... In the same thread.
2000 Silver SVT Lightning
Silver Lightning RC
2 1:21 Burago Lightning Models
1999 Grand Am GT
[This message has been edited by 2000Silverbulletonorder (edited 04-24-2000).]
Silver Lightning RC
1999 Grand Am GT
Babolt
I tried to send you some PROFS messages last week. Wasn't sure if you got them or not. PFA said you were sick last week. Like I said I am in great need of a taller tire. Ihope this wheel will work. Mike at Lightning Perf. asked me about where you got the wheels. I told him I'd ask you but haven't seen you since.
Big Poppa,
The reason for the man. switch on the intercooler is so I can circulate the coolant and run the fans while I am waiting in the lanes to run. The switch is a two pos. Switch in pos.#1 ON even if ignition is off. pos.#2 pump runs just like stock. I have found the cooler you can get the supercharger the better it will run. I even gone as far as putting two 5lb. bags of ice on the supercharger and letting the truck sit for 45 min to an hour. Pushing the truck through the staging lanes. Start the truck right before the burnout, stage and run it as quick as possible. It sound silly but I've seen .2 improvements in my E.T. by only iceing the S.C.
HIGH RISK
Big Poppa,
HIGH RISK
