Removing bed need assistance.
Going to change my fuel pumps, as well as check for a couple exhaust leaks and clean up the frame a bit.
I did a search and came up with a few tips. Im going to just remove the bed and lift it with my lift. What I got is there are 6 bed bolts, a wiring harness, and the fill tube for the gas tank.
My question is are there any other components I have to take care of before I lift the bed??
What do I need for tools (are the bed bolts torx???)
Yup, big *** torx, T-50 (just verified it!) ... And they strip very easily.
It's the biggest one in the Craftsmen set.
And a ground strap by the downspout.
I only took mine off to do Stan's Panhard so I am not sure what FULLY
taking it off entails ...
Originally Posted by Tim Skelton
Can you post some pics of the process, Talli?
I am going to remove the bed someday soon and would especially like to see the fuel filler removal process.
Just undo the large & small worm drive clamps and remove hoses near to chasis above tank. a bit of time to remove hose from metal pipes and when replacing a smal amount of silicon grease or rubber lubricant (no questions re the latter pleeesse)
Dropped my tank down (1/4 full only) onto two wooden blocks and had enough room to disconnect lines and remove complete pump & sender unit in one.
Easy job to swap pumps over in the end mate.
A man with your skills and workshop will turn job round in under the hour.
Ricki
Originally Posted by brahmus
the seat torx or 55 i think. I think the bed bolts are actually 52 and that is why the 50 strips them but I have only found a 52 once.
What is really confusing and sent me to the store twice
is that the bolts are stamped with a "60" and I thought
that was the size ... Actually not.
