Need help on stock lower pulley...
Try this in reverse:
http://home.insightbb.com/~svtvideo/...ey_Removal.pdf
Thanks to Cliff(SVT_KY) for this
And remember that the drivers side has TWO nuts that go
on top of the pulley. (It REALLY squeals when you put a nut
on and then the pulley and then the other nut.) (Not me!)
So you should have the three nuts on the studs on the bottom end
and a bolt on the right hand side jsut below the throttle body.
