Can't retract a set of Pistons on my Wilwoods
I was performing my annual pre-season brake isnpection, bad swap, brake bleed and ran into a problem retracting a set of pistons on my Wilwood BSL4 calipers. The passenger side went smooth, but I am not able to compress the inner, driver's side set of pistons into the caliper. I've removed the old pad and installed the wear spacer in its place, and use a c-clamp to compress the pistons. Any advice...
