Ok "maybe" I over re-acted, 11.6 first try aint a so bad....
#106
Originally Posted by Rob_02Lightning
I do know the Mag DID put down 606 HP, (and that is KB BIG)
#107
#108
At the end of the day ALL OF THIS could have been avoided if I was simply told what tunes I really had, looking back I honestly think Jim simply forgot to have that converstion with me.
Or by just picking up the phone.
Because everybody knows that smoking pot 24/7 for 30 years doesn't affect your memory
Originally Posted by Odin's Wrath
On a 9.1:1 compression ratio built engine, with cams and heads, right? 8# lower pulley and 2.70 upper? I'm willing to wager that you could have done that with the stock Eaton. You for sure could have done it with a port job. If you ever put a KB on that bad boy, you'll be very pissed off that you spent one red cent on the MP. Believe me.
Bolting the Magnum on my stock longblock with the same pulley combo produced 530rwhp with less heat.
But the truth is I probably would have bought a KB. But on another board Ken from KB told me, when asked about the locking up problems, that there have been NO KB's locking up and returned for warranty work. Because he personally see's every KB returned and none have been returned. To KB's credit they fixed the bad blowers and corrected the problem. But lying to me online when I personally knew of 3 that had been returned, and a couple more than once..........put a anti-KB taste in my mouth. I wouldn't own one if they where free and came with a $100 bill taped to them.
#109
Originally Posted by Fast Gator
Sorry, I can't believe you because I saw it first hand on my truck. On a stock long block, a ported Eaton (From Apten) made 488rwhp. That was with a 6lb lower and a JL 1 lb upper.
I was starting to think something was wrong with my truck. The Whipple came out and I decided to go for it. With 2# less boost, I am making 500 rwhp SAE and 600 ft./bls. of torque. Stock longblock and only 14 degrees of timing (and BIG pig rich a/f ratio). At 5500 rpms, I'm making 150 extra hp over the curve of the MP with the same timing. (BTW, I saw no problems with the springs allowing the valves to float (As Rob did) in my dyno charts either. How your truck made 530 rwhp with essentially the same setup as mine, is beyond me. There are several guys here in NC that have had exactly the same results with the MP, and didn't give it a full year, as I did. One Harley guy ran his for less than 6 weeks before ripping it off for a KB.
Remember the results your truck got with the phenolic spacer? I don't know anyone else who did the same. You either have a magic truck, or you're tuned with pixie dust on Merlin's own dyno.
I avoided the KB for similar reasons. Valid or not. I mentioned KB as it's cheaper than a Whipple and I know Rob wouldn't be interested in a $3600.00blower when he could probably pick a used KB up for less than $2000.00.
#111
#112
#113
Originally Posted by rscoleman
The MP is the John Kerry of blowers. First it's the best/safest/softest blower for stock engines at low boost, then it needs to be spun at high rpms to make power, now you need an aftermarket valvetrain. What's next?....it only works with aluminum blocks...
On the plus side, they're both screamers if you ever mount 'em.
#114
My built motor MP truck made 540 on the street tune. The race tune is very rich and needs more timing. It is .2 better than my street tune, but not yet dynoed. It has now run 11.2 with a poor 60' and my 290# azz driving. There is easily more there(see Gator's 10.9).
While not being able to move quite as much air the blower is only .4 or so less capable. Stay tuned for nitrous #s even though it was reported that the MP trucks don't respond well to it!
#115
#116
WHO CARES WHAT YOUR TRUCK MAKES ON THE DYNO!
I have more dyno runs at JDM than anyone I know - that doesnt mean sh-t to me!
The only thing that matters is what it does in the 1/4 mile
I had a MP on my truck and it made 67 hp over my ported Eaton but i never saw the diffference on the track.
On the street was a different story all together. Vinnie and I got into it a little on the highway once when he had his KB on and I stood right next to him for quite a while until the MP ran out and the KB kept pulling.
Honestly the Mp is a great street blower but in my opinion it never produced at the track.
To me the KB is a much better supercharger
#117
Sorry Gator; but, I can't believe you either. I was making 380 rwhp with a 2# lower and 2.80 upper on the stock eaton. After only the MP being changed, I lost HP and torque, with the same tune. I was upset. I called JDM and was told that you had to spin it harder to see the benefits. I bought a 6# pulley and a tune. I made a best of 425 rwhp SAE with the MP, a 6# lower, and a 2.7 upper at 18* of timing.
i had very good results with the magnum,,,on the dyno it only showed minimal results,,but the track it shinned,,,it did need to be spun hard,,,much harder then most pepole are willing to spin them on stock blocks
i dont think they have the volume for a motor with cams and ported heads,,,once i added the cams and heads i only seen 16lbs of boost,,that ws with a 2.7 upper and a 10" lower
it seems like most kb guys arent seeing much more then that with the same combo,,,(in my area)
