HANDLING UPGRADES?
HANDLING UPGRADES?
I am very suprised that the 95 lightning I had without a doubt would out handle my 2000L. I am curious is there any suspension upgrades out here that will help the truck thru the corners without lowering the truck? I use the truck to pull a boat and I can not loose any more clearance or I will drag the front and back of the truck.
Collins...I am in the exact same boat (HA!) literally as you. I have to drive mine in the winter. At most, I wouldn't want to lower it any more than 1" but it's a real challenge to find any company this is making that.
However, for the time being, I am going to perhaps go with a different shock. I am leaning towards the Koni's if they are made for this truck. I just need to find a few part numbers. Hopefully someone will also make some urethane bushings for the sway bars, althought the bar bushings are pretty hard as it is, the endlinks could perhaps be changed instead.
Paul G.
Paul G.
