Polyurethane Bushings
Neal,
Prothane kit 6-212
I bought it at JC Whitney of all places for $69.95 yet that was right at four years ago.
https://www.f150online.com/forums/sh...light=prothane
Bob
Prothane kit 6-212
Bob
Bob:
I'm stuck right out of the gates.
The stock bushings have some caps pressed on.
I have a full complement of ball joint presses. I even have a 6-ton hydraulic bench press. But damn if I can figure out how to get these off.
It doesn't look like you can press them out because they are only a mm or two thick. Nothing to grab onto inside the barrel.
Prying from the sides? A gear puller?
Heres some others
http://store.summitracing.com/egnsea...15&Nao=0#rstop
WHen I did my fronts,it was fairly easy.The instructions were good and I didnt have any problems.To get the stock bushings out just get a torch and heat them up till the pop out.Just make sure your not in the way when they do pop
Tim,
When I did mine several years ago I took the control arms to a local alignment shop. They did the press in/out work. Took them about 20 minutes total. I think they charged me about $40. You need someone that does suspension work. Most job shops don't have the fixture needed to press them.
That's not a fun job but when I got this done several years ago, I gave it to a pro. He told me that he cut the bushings gently in order to re-use the sleeves.
Doing this does tighten things up but it does harden the ride quite significantly. That's what I noticed anyway.
Tim,
Are you going back to the stock control arms?
TB
Tim,
TB
