Vacuum and Rear Main Bearing Noise...Yes
Well started pulling hoses off and when I get to the drivers side pcv valve I pulled it...Noise ceases. The noise is not at the hose but at the rear main bearing....So...there was a nice vacuum at idle on the valve cover. Since the pipe form this side goes to the Throttle Body hose..you know one of those three..For sure at idle there is a good vacuum ....on the valve cover. Turn the PCV around and stick it back in....Vacuum...All I need is a hose and filter and I can Vacuum the interior....
you mean this hose?
I put a new one on last week...while I had the blower off....
I have pulled the pcv off the drivers side valve cover and just run it without a pcv valve......the line still runs to the intake hose before the throttle body...I think there was not a pcv on the drivers side originally..but think I added this as insurance against oil in the intake.....hell I could be wrong..
