SCT 2400 MAF with stock injectors......
well
All i wanted to do is upgrade the maf because with the ported blower and 6lb lower with headers, i know i'm pegging it in the cold because at the track in the fall around 4500 rpms my wideband started leaning out to up over 12.
I upgraded the pumps so i know that wasn't an issue it it wasn't happening when it was warmer out, so it was more of a safety precaution. I really didn't want to get into changing injectors because 60lbers is overkill and i heard of alot of issues with the 50 and 55lbers. Plus the cost is the big thing.
I don't know what is going on to be honest except Jim said he didn't have a program for an sct maf with stock injectors and would have to create one and that while doing it, there was a couple of issues. He pulled in a truck that was there and played around with it and the maf to create tables. He's had my chip for over 2 weeks now (I know they are swamped)and i've been borrowing my dad's truck for transportation so I told them if they couldn't get it figured out, just send my chip back for now and let me know when they get a chance to work on it, then i'll send it back. Obviously would be easier if they had my truck there on the dyno but with the wedding comming, i can't afford to be dumping all this cash on the truck so I just assume go back to my 4lb lower, stay with the 90mm maf and call it a day for now. Whip has some injectors if i need them but if i'm gonna go for injectors, i can't see having an accurate tune without putting it on the dyno. I'll call them tomorrow to see how they made out. I guess this wasn't as simple as I though, but nothing usually is. Haha.
Sal
Don, why not just add a MAFia?
I'm open to all ideas I guess. I know in talking to you, you said you had to start from scratch with the 2000 trucks. I think that is what Jim meant when he said he had some things that he wasn't thrilled about.
Don, At the end of June, I think the 29th, I have an appointment with JDM. One of the mods I'm doing is a SCT programmer, I'll have my single program Superchip left over, it's a freebie if it'll help you out, I can leave it with Jim so he can work on your program, this way your not down while he works out the bugs. Todd
No problem Todd
I talked to JDM this morning and they sent me my chip back so I can drive my truck while they work on it . I should be fine untill the colder weather comes, but I'd drather be safe than sorry. I'm sure there will be quite a few folks upgrading maf's with stock injectors so hopefully it will help more than just me.
Now I know why I should have gotten the XCAL!!!! Hahahaha.
