word from SVT on ic coolant mixtures
According to the SVT folks a 50/50 mix is correct for the intercooler coolant and the manual is wrong to ask for 100% antifreeze. We should be able to increase the water % content quite a bit before getting into any issues associated with boilover. SVT recommended (and I agree with this) the use of distilled water with any antifreeze/water mixture.
Also, the pump used for the intercooler fluid is the same as that used on the "electric Rangers" in a standard radiator context, so it is a pretty robust unit. There is no special lubricant issue requiring such-and-such amount of glycol.
Now the question I have is, how far can we go with the water --- 60%? 70%? 80%? Has anyone got data on how hot the fluid gets in normal driving? If it -never- gets near the boiling point of water we could conceivably get to 100% distilled water. I'm guessing that isn't the case, however, and some boilover protection is always needed.
-tvw
[This message has been edited by tvw (edited 06-14-2000).]
-tvw
